Benlari (Amazon) Gloss Black Mid-Frame Air Deflector/Heat Shields
South Jersey Dave
23
16
For those of you who are considering a mid-frame air deflector/heat shield and don't want to pay top dollar or care about color matching, I just bought this Benlari model on Amazon and can report that it DOES, in fact, fit the 2024 touring models.
If you read the reviews you'll see a fair number of folks who say otherwise but they fit my 2024 Street Glide without a hitch. Yes, it does just barely touch the underside of the gas tank so if you're concerned about it I suggest adding a small strip of black electrical tape to the top edge of the deflector prior to installation. I didn't bother but that's just me.
As suggested by the fine folks at DK Custom Products, I only installed the right side, leaving the left side open so that air flows in the right side and out the left side rather than forming a hot-box under the seat. Based on the reviews, this has the added benefit of not having to contend with installing the left side, which seems to be a bit trickier than the right side (and which is typically hotter than the left side).
Regarding installation, the hex nut fit perfectly into the hexagonal hole in the frame and snugged up nicely upon the final tightening of the bolt.
Installation was a breeze, due largely to my having been fortunate enough to have had the right tools for the job. It's a tight fit in there, especially for the upper bolt. Both are Torx 25 and I was able to use a stubby rotary wrench for the lower bolt and a flat angled wrench for the upper bolt.
As for functionality, it does make a difference in the amount of felt heat but it's a modest one. In addition to use as a stand-alone solution, you might want to use it in addition to a few other heat mitigation efforts such as a tank lift, cooling deflector wings, external fans, etc.
If you're angling for a means of reducing some of the heat you're feeling when you ride, I suggest giving these a shot. At this price there's little risk. Since the functionality is identical to the costlier versions sold by HD, Advanblack, Hogworkz, etc., you can give these a shot, see if they work for you and if so pony up for the costlier color matched or OEM versions.
You can take a heat gun and heat up the deflector, now that it's installed, and push it down from the tank. It wouldn't need much.
  • Like
Reactions: South Jersey Dave
nigeloscar
