Accessory switch
KWbond
6
2012 Street Glide, accessory switch lights up when I turn it on, pulled the seat off, I can not find the connector to this ACC switch,
This is what I found under the seat,
Below the gas tank center, single Grey connector, hot all the time
Right center near the Battery, oval black connector 2 pin, no power with Acc switch on,
Left under side cover Grey 4 pin connector with only 3 pins, all 3 pins no power with Acc switch on,
I am using a test light to make sure there is power, one lead to ground, other lead to pins,
Is there a connector I am not finding?
If there is another post for this please link me to it, I looked did find, but found a lot of good info for my tunes I will be installing next......:eek:
Thanks for any help,
UPDATE
I dug a little deeper under the seat area, center of the gas tank, and guess what I found, yep the connector for the accessory switch, hidden behind the other wires,,,,I would still like to know what the other connectors are for if anyone knows
Thanks,
Kyle
