Anyone Running S&S Power Tune Duels and Rinehart 4" Mufflers?
w1smc
63
I just received my Rinehart 4" mufflers ......
I was thinking about the V&H Dresser Duals but thought about the S&S Power Tunes Duals ....
If anyone out there is running with this setup I'd be interested in your thoughts and input ....
Thanks
I have the S&S Power Tune Duals with RC Components RCX slash up mufflers. Very happy with the setup, performance, and sound. I like the clean look of duals without a big X or nameplate on some others. S&S still has a crossover but not visible. A little tricky to get on, but not bad. S&S has always made good stuff, highly recommend as an option if your looking at systems.
Thanks for the input ......
I still have time before I pulled the trigger and I'm just gathering up data ......
The plan is to get the mufflers, headers, A/C & cam update all done at my 1K maintenance .... just get it all done at once ......
And I have yet to decide on the A/C unit ..... and ..... cams
I'm looking at the S&S cams too .... along with HD of course .....
We shall see ......
We shall see ......
Cams not enough hp per price. If go that far go to 110 motor.
Good point .....
I never gave it a 2nd thought really ..... I mean, just how much of a HP gain will I achieve with say a 585 cam upgrade after the new mufflers, headers and A/C upgrade?
What's the baseline stock HP of the 103 motor?
Good point .....
Harley tech an parts manager talked me out of it. New creat motor 120 installed was only 5000 $ cam job alone done myself was around 1500 $
I'll look up my numbers before and after
Stage one air an hi flow screaming eagle exhauste one min
Hp before 103 stock 66.5 torq 85.9
After stag 1 intake and hi flow screaming eagle head pipe and cannon muffler w screaming E race tuner
79.82 hp tq 97.70 If I change motor any more I'll go 120 motor
Hi flow header is 2" outter diameter with cats relocated in muffler
I'm running that exact setup with SE Elite air cleaner and the fp3 tuner. Runs very well sounds great still haven't done the auto tune with the fp3 but runs very well with the base map Vance and Hines recommended. Only issue I had was the right driver floorboard was rubbing on the head pipe a little. installed floorboard spacer kit plenty of room now and the riding position is a lot more comfortable with the spacers. Hope this helps with your decision.
Thanks a lot for the input ..... This is exactly what I'm looking for .......
Do you remember which map V&H recommended?
Also, do you have the part numbers for the floorboard spacer kit? If I need this kit I'll just work it into my plan ....
Again, thanks .....
Sent from my iPhone using TapatalkView attachment 10844
Nice ride
V&H suggested the Power Duals w/ hi output slip ons for my setup. I have since autotuned, runs great.
Again, thanks .....
It was power tune duals and I think twin slash rounds I'll have to check on that when I get out to the garage. The spacer kit was Kuryakyn 7509 spacers cheapest I found was on Amazon for $37. Hope this helps enjoy the ride.
amelia.jam2005
