Condensation
Stl-BooDog
29
I recently installed a set of Bassani DNT Mufflers on my 2017 Street Glide Special.
I absolutely love the sound, it's better than I imagined...
During the last few startup's I noticed condensation dripping from the rear of the mufflers, no big deal.... But I also see drippings where the mufflers connect to the head pipes!
Is this something I should be concerned about??? Is it possible the mufflers aren't clamped tight enough around the head pipes?
I see drippings on both the left and right sides.
Sent from my Nexus 6P using Tapatalk
I also have the DNT exhaust and noticed some condensation coming out of the back until it heats up. Nothing rusted or corroded. I have not seen it drip by the headpipes. Are the bolts torqued down enough ?
Everything appears to be tight, maybe I need to slide the mufflers on the head pipes a bit more...
Thanks for your reply, much appreciated....
Are they stock head-pipes? I am running Fullsac DX and I have a tight fit between the exhaust and head-pipes.
SGTim
