Finally! Have you seen this ?
pyuchem
102
I’ve been looking for easy pull on clutch for long time. I already have AIM VPC and like it. But would have been nice if this would have worked on my 2016 street glide. Check it out.
LIGHT FORCE CLUTCH SLAVE CYLINDER
Item Light Force Slave Cylinder
Parts # LF001-001
MSRP $280
Fitment
Harley Davidson Assist and Slipper Clutch; 3 Stud Style Clutch.
2017 and later Touring Models M8 engines equipped with a hydraulic clutch.
Street Glide
Road Glide
Road King
Electra Glide
Features
Easier to pull: 40% lighter clutch pull.
Black Anodized with special coating finish for high durability.
Will make the clutch engagement point closer to the grip for easier clutch modulation.
Uses factory hardware.
Installs behind the factory transmission end cover.
Quick Installation, no modifications needed.
Kit Contents
Fully assembled Light Force Slave Cylinder
https://aim-tamachi.com/collections...ce-easy-slave-cylinder?variant=12539684356119
I won't lie this really has my interest. I commute daily and crawling down the i10 while holding the clutch gets tiring some days! I was playing with a r1200rt and the first thing I noticed was the clutch was super light.
If you don't mind me asking; why are you switching away from the Rekluse? I ask as I'm seriously considering it for my bikes... And how many miles on your rekluse? Will it fit a 2018? How much?
Been there done that. I loved my rekluse but I took it out last year. I've it for sale if someone needs it.
Had it on my 2016 sgs. I used it for road trip doing cross country around 7000 miles in 2 weeks. I loved it but only thing I didn’t like was You have to use a Velcro strap they give to tie ur front brake with throttle or else bike will roll on if it’s not parked on flat surface. See with rekluse ur bike is always in neutral unless ur giving it a throttle. I’m sure it will work with 2018 , I’ll check with rekluse.
I always park my bike in neutral on hills and my bike never rolls at all, turn the wheel maybe?
