Front wheel.
Glide585
10
Can someone give me a ball park cost of changing front wheel to a 21? I would like to change the front fender also.
Thanks
yes I just did on a 2011 you will need to lower the forks to 1"-2" to keep the stock look & handling the same I put in progress mono tube sys, very nice ck it out on line and this is gook time to chrome tubes on or black & change your cow bells out then I drill out my fender two drill bits bigger and lift up the fender a little for a no rub with any tire you pic out & change out your brake pads to new one for a new true fit it a little $$$ up front but you only will do it once!!!! good luck
