Need advice
BgVegas
10
I just purchased a 2014 FLHX. I'm installing Freedom Exhaust this week. I would like to do an intake as well.
1) Which intakes are recommended?
2) Do they need to tune it because of the intake or is there something else I can do?
Thanks
There is so many options for intakes. For me I like the looks of the HD elite heavy breather. If you install your pipes along with an intake you have to do a tune, you can either go to Harley and have them do a down load for a couple of hundred bucks, but I would recommend buying a tuner. I went with a Power vision. For me it made the most sense, since I don't leave anything stock and it's easy to reprogram it later.
Need advice
Thank you. Would I need to use a Dyna or is there another way to tune without one??
BgVegas; As an option several on this forum have recently purchased the new V&H FP3 tuner. Not only does it do an Auto tune & downloads but anytime you make changes, it can adapt to them w/o the need of a trip to the Dealer or Dyno guy. They're fairly priced and there are discounts available from sources on this forum such as PCPain and Kutter HD. Spazz lives in NV and has one, check out his thread here. WELCOME from Nashville, TN
Jimrogers74
