Removing saddlebags
Raza51
4
How do you remove the saddlebags on a CVO 2016 street glide :mad:
Pm sent
How do you remove the saddlebags on a CVO 2016? :mad:
Open your saddlebag lid and look for these clips ( i have attached a photo) turn each clip counterclockwise this should release center of clip so you can pull it out and then lift bag off.
On the CVO, don’t forget to unplug the audio cables, one side to pull up on the release tab and on the other you push down, as your pushing or pulling the connector will unplug
Eric375
