Screamin Eagle a/c
buckshot85
844
View attachment 8830View attachment 8831
Anyone ever install a Screamin Eagle Ventilator air cleaner kit #29400217 on a '14 or newer bagger? I just installed mine and it tips forward and is not level. There is no slack to rotate it back to level. I really do not want to egg the holes in the backer plate. Looks worse in person. Thanks for any input.
The hole pattern in the backing plate must be rotated to cause that. See if the backing plate holes are properly aligned.
I just looked at mine and it looks pretty much like yours in the photos. The top of the filter is parallel to the bottom of the gas tank.
Here's some pics I found online.
It seems true with the heads. Just looks sorta crappy to me. I think they could have rotated the bolt patterns 2 degrees and had it look better.
Jimrogers74
