Stage 1 Kit w/ V&H Power Duals and SE Street Cannons
HarleyAl
9
Recently picked up my '16 SGS from having the Stage 1 Kit completed.
I went with the Vance & Hines Power Duals, Screamin' Eagle Street Cannons, HD High Flow Air Kit.
I got about a 7HP increase that can be felt and a great deep rumble when you get on and off the throttle.
I thought I would get a little more HP, but I am happy with the results!
You could remove the cat from the stock header and squeeze out a few more. I got 88/111 with HD high flow filter, no cat header, and Rinehart 4" slip-ons
EDIT: Never mind I missed the power duals part.
Stage 1 Added
Stage 1 Added
View attachment 11207View attachment 11208
I don't see where you had a dyno done, how do you know you got 7 hp? I really don't think you got that much from what you did. You probably did get better response since you are moving more air thru the engine.
According to most listings, the SG has 76hp stock. The Dyno run photo in post #1 shows about 82.65hp.
SGTim
