Vance and Hines VO2 Naked Air Filter
Terrymac
4
Hi
I recently fitted V & H Monster Squared Mufflers along with Bluetooth Fuel Pack and a V & H VO2 Naked Air Filter with Stock Cover on my 2014 Street glide.
Everything ran smoothly until I tried to fit the Air Filter Assembly as the Cylinder front and back breather pipes were fouling the cover and the filter would not sit flush on the backplate.
I tried all ways to get it to fit with no success. The front and back rubber breather pipes have a bend in them which goes through the backplate and fits into a machined cut out in the aluminium venturi assembly. The filter was catching on these and it was impossible to get it to sit flush. I ended up cutting these bends off so the breather pipes sat flush with the front lip of the venturi cut out.
I have run the bike down to Europe and covered around 1500 miles and it seems to be running fine but all websites I go on it shows these bends in place. Just wondered if anyone else has experienced this problem
Nope, mine fit exact. Maybe you got the tubes backwards, or the venturi not positioned correctly?
Thanks Corey I need to have another look at it when I get home and probably order two new pipes
I could take some pictures after I get home tonight, if that would help.
My bike is a 2009, so I don't know if there's a difference with yours, but here's the pics of how mine looks installed.
Thanks Corey that was very kind of you and it is clear now, I have fitted the pipes wrongly so will sort it out when I get back to the UK, once again much appreciated
You got it brother!! Hopefully it all goes together the right way this time...good luck!
