2007 SG spacer question
DannyB
I am needing to either have a front bearing spacer made. Not a stock length , any ideas where I can get that done, Other possibility is to use 2 inner spacers cut to make up lenght, but is it ok to use two. Thanks
Most local, to you, machine shops should be able to make a spacer for you. Personally I wouldn't use the 2 spacer method.
I am needing to either have a front bearing spacer made. 3D nyomtató filamentek típusok Not a stock length , any ideas where I can get that done, Other possibility is to use 2 inner spacers cut to make up lenght, but is it ok to use two. Thanks
A local machine shop is usually your best bet for a custom length to ensure it's perfectly square. While some guys run two spacers, a single solid piece is definitely the safer way to go to prevent any shifting or alignment issues over time.
Webike Japan
