Changing to LED Headlight on 2010 CVO?
ultrastryk
12
I've done a fair amount of reading on LED headlights. My question is what will fit my 2010 CVO street glide? Do I need a different trim ring to install the JW Speaker or Truck Lite?
Thanks
I believe you should be just plug and play on either one, you shouldn't need to change your trim ring either.
I know that the newer SG is simple, but I thought I remember someone with an older SG saying his trim ring didn't fit the JW Speaker LED
Not 100% certain about a CVO, but with a standard 2010 SG, you will need a new mounting ring. However, you will not need the adapter harness from HD.
