Dyno Numbers
dirtdiver8282
I was wondering if anyone had any ideas on if the HP and Torque numbers sound right. I have a 08 Streetglide and upgraded to the S&S 106 big bore kit, woods 777 cams, big sucker air cleaner, bassani p plus exhaust and running a TTS master tuner. dyno numbers before were 94 HP and 104 TQ. New numbers are 97 HP and 110 TQ. What am i missing here lots of time and money for little gains? Any advice would be appreciated and I look forward to reading this forum and being a member.
Thanks
Check the cold cranking pressure to see if your compression ratio is correct. Should be around 200 psi.
What heads and modifications do you have?
the heads were stock just a big bore kit. Im going to have some compression test done. I think i am going to get some head work done and look at another cam. Thanks
chip geisberger
