Location of adj. gain controls on J&M Rokker 250W 2 channel amp
NGOT8R
63
Before I explain what I did, I want to first say that I am well aware that I may have voided the warranty on my amp and that's not something that I'm worried about. Now for the explanation:
I searched to no avail and couldn't find any information on how to adjust the gain on the J&M Rokker 250W amp, so I decided to see if I could locate the adj. gain control potentiometers or pots on my own amp. I removed the six screws on top, removed the lid and there they were; two orange pots labeled CH1/Left and CH2/Right. Before making any adjustments I took note of the current position of each pot, so that I could return them to their original positions if necessary. CH1 was turned all the way clockwise and CH2 was turned approximately 95% clockwise. I tried various settings and did not notice any change at all in sound quality. I even tried moving the input level switch for preamp/speaker on the left side of the amp to both positions when making the changes. I found that moving the switch to the speaker position caused a ticking sound to be emitted through the speakers. However, the ticking sound is almost completely filtered out when the switch is placed back in the preamp position as received from J&M. Needless to say folks, I believe that this is as good as it gets with this amp. I just wanted to share this information in case someone else was thinking of trying this. Here are a few pics of the amp's internals.
NGOT8R ,,,,,,,
Good post but I think something is broken with your amp gain screws ,,,,, first of all, none of our amp gain screws have ever been adjusted from the factory at anywhere past about 60% of max ,,,,,,,
for another perspective on how to adjust those, please take a look at this video ,,,,,,,, https://www.youtube.com/watch?v=Y6C5MiRGq1Y ,,,,,,,
the later model ROKKER XTP amp are all software controlled for their gain adjustments so that video would not apply ,,,,,,,
NGOT8R ,,,,,,,
John,
My amp does have a DSP port on it. Is it possible that the gain control pots are purposely disabled from the factory on amps with DSP ports since the gains need to be adjusted via software using the J&M dongle? Does the end user have much flexibility in making adjustments via the software and dongle?
John,
I wasn't even aware that J&M made a 250W amp which does have the gain control settings that can be accessed from the left side of the chassis until you responded to my thread. I found these pics of what appears to be an earlier version of the J&M 250W amp. Having said that, I now completely understand that I need the J&M dongle to fine-tune my amp and will be ordering one soon.
Doclee
