Maintaining A Charge On My Battery
paratrooper
Hello,
Can someone please tell me if this is a good idea? My motorcycle is stored in my shed. My shed has no power. I've been quoted $3000.00 to run power to it. I'm wondering if I were to buy a solar generator (leave it in the shed) and connect it to a solar panel mounted on the outside of the shed, if this would work to keep a good trickle charge on my battery during the upcoming winter months. I've never done anything like this, and I may be over thinking it, but I would love if anyone thinks this will work or has a better idea.
Take your battery out and bring it into your garage and charge it there.
  • Like
Reactions: dogmom
I definitely have considered that, I live in Tn where you can ride almost year round, and I'm trying to find the most convenient way to maintain a trickle charge, while not having power, and not having to remove battery so often.
A solar unit would work if it supplies the proper volts and amps for the charger (maintainer) that you use. Just need to make sure that it remains clear of mother nature.
Hello,
Can someone please tell me if this is a good idea? My motorcycle is stored in my shed. My shed has no power. I've been quoted $3000.00 to run https://zumbaliciouscrew.com/en/zumba-online-class/ power to it. I'm wondering if I were to buy a solar generator (leave it in the shed) and connect it to a solar panel mounted on the outside of the shed, if this would work to keep a good trickle charge on my battery during the upcoming winter months. I've never done anything like this, and I may be over thinking it, but I would love if anyone thinks this will work or has here a better idea.
Using a solar generator and panel setup to keep your motorcycle battery charged during the winter is a practical and cost-effective solution, especially considering the $3,000 quote for running electrical power to your shed. Since you’re looking to maintain your motorcycle’s battery over the winter, a solar setup could work well with minimal investment compared to the quoted cost.
Here’s how it can work. A solar generator is essentially a portable battery that stores the energy collected by a solar panel. You can mount the solar panel on the outside of your shed to capture sunlight, even in the colder months. The energy from the panel would be directed to the generator stored inside the shed, which would in turn keep your motorcycle battery charged via a trickle charger.
Trickle charging is ideal for maintaining the health of a motorcycle battery during periods of inactivity. Most modern solar generators come equipped with ports for connecting trickle chargers, so you won’t need to worry about whether it’s compatible.
There are a few factors to consider:
Panel Size and Sunlight: You’ll need a solar panel that generates enough power to keep the generator charged. Depending on where you live, winter months may offer limited sunlight, so a larger or more efficient panel could help ensure you’re still getting enough power. Fortunately, a motorcycle battery doesn’t need a huge amount of energy, and solar trickle chargers typically don’t require large solar setups.
Battery Maintenance: A trickle charger draws very little power, so even on cloudy days, a well-sized solar panel and generator combination should provide enough charge to prevent your battery from dying. The key is ensuring the generator can store enough energy between sunny periods to keep the charger running continuously.
Costs: Solar generators range in price, but you could find decent entry-level ones for a few hundred dollars. Solar panels are also affordable and vary depending on size and efficiency. Overall, your total investment in this system would likely be far less than the $3,000 quote for running electrical power, and it would offer a long-term, low-maintenance charging solution.
In short, yes, your idea should work well to keep your motorcycle battery topped off during winter. If you get a properly sized solar generator and solar panel, this setup would not only save you money but also be more environmentally friendly and provide ongoing power for future needs, all without needing to wire your shed.
Or he could go with what was already mentioned. But then there is this one by a well known manufacturer: https://www.batterytender.com/produ...w-solar-battery-charger-with-windshield-mount
waialeasdad
