No accessory plug under 2014 seat
wallyjar
27
I picked up a demo seat from the dealer to try out. Road Zeplin with adjustable air bladders inside. Told to look for accessory plug right in front of battery under seat to plug airpumps into.
Looked for an hour and could not find. Took to dealer Thursday and two techs spent 30 minutes tryong to find connector and they could not either. This plud is needed for audio, heat and other stuff.
They are calling to MOCO this AM to see what is going on.
Who has installed audio of heated seat in 2014 SGS and can shed light on what to do here?
Not sure if its the same plug/harness but...
There is an ACC plug... you need the harness to run it from the left side panel up under the battery. It's about $20-$25 if I recall... I added one for my HD GDO ( Garage Door Opener). It carries a ground, a switched 12VDC and constant 12VDC. The instructions say you can add up to 6 accessories with this harness.
I can get you the P/N after work...if you want it... if I still have the packaging.. which I should
Also... if you find the PDF files on the install for that particular seat on MOCO site... it may lead you to the plug/harnessv P/N required.
I also added that harness for my GDO. It is $20-$25 for it. Your dealer should of known that.
Thanks. They are calling HD but think it will require a harness from front of bike all the way back.
I agree adaptor from seft side to under seat will do it.
I can look it up in the electrical service manual tonight.. might be able to find something....
Did you ever find the part number?
Maybe I'm wrong but does that plug into the same location the V & H FP3 plugs in to ?
That's where mine plugs into.. fed it up under the frame and on top of tje battery
It's not the same plug, but the same location as the plug for my FP3 under the left side panel
Its under the left panel, there are two plugs and one for the alarm (siren). one of the larger plugs is for access to the ECM, the other is for the accessories. you can split the accessories with an adapter from Harley, just don't exceed 20 amps or the BCM will shut everything on that circuit down(electronic fuse). The BCM is an interesting gadget, the manufactures have gone to lesser gauge wire and this protects it, instead of causing a fuse to fail, this thing shuts the power off to only that system, thus saving the wire and fuse. If you are hard up for entertainment try and install a 1157 bulb (front turn and running light) backwards while the ignition is on and you can get an example of how it works. If anybody needs the part number to double the accessories socket, let me know.
Gator1
