Smoked rear signal lights
WaterBoy
Just wondering if anyone had better idea on what bulbs to use on 2015 street glide.
Just got done putting smoked lenses on and red bulbs in rear and they are really dim and almost pinkish color.
Been googling and I'm sure someone else has had this problem, thanks
CustomDynamics.com "dual intensity red LED's"
None brighter for both tail & brake lights in my opinion.
The below vid shows the led turn sigs with smoke lenses on an RG. He also has Custom Dynamics plasma rods & their tribar. I have the same set up, but even without the rods & tribar, it's plenty bright.
http://youtu.be/lBY9whsxUNE
Nice...like how bright they are!!
Yes do the Custom Dynamics it's a plug and play 10 minute install. Get the rings for the front and brighten that up also better to be seen.
Hey Waterboy.
The below youtube link (lousy vid) is my bike. I have the 48 LED cluster inserts on rear with the Harley smoke lenses. **The LED CLUSTER is actually CLEAR when my ignition is OFF...When I turn ignition to "ON", they turn RED.
I also have the "magic box" from Custom Dynamics under my left side cover. The magic box gives you a strobe effect (10 different settings). I have it set to STROBE FLASHING for 4 seconds when I apply my brake... Then goes to solid brake (QUITE BRIGHT). You don't really "NEED" the strobe unless you REALLY WANNA GET THE ATTENTION OF THE MOTORIST BEHIND YOU.
Without the box, it's just plug & play. Take the OEM bulbs out and put the CD inserts in. Simple.
If you have any questions, Custom Dynamics has a great staff and will help you make a better informed decision.
Like TomA said, the Custom Dynamics "Dynamic Ringz" make a great addition to your front running lights/turn signals. They have a very bright ring of multiple LED's as running lights, and the center turns to flashing amber cluster when you hit your turn signals or flashers. It's another lousy vid of my bike below
http://youtu.be/vzkxiJwPOLA
http://youtu.be/FwAj8DBu9BI
I'll do a +1 on custom dynamics. I have the dynamic ringz and plasma rods. I get asked all time what lights I have because they are so bright.
Did you have to add a voltage modulator?
I have the custom dynamic led tail lights with smoked lenses and love how bright they are. I also have the custom dynamics rear fender tri-bar light. Its a lot brighter than the factory tri-bar light and turns into a brake light when the brakes are applied. You won't be disappointed !!!
amelia.jam2005
