*SOLD* Genuine Kraus EZ-Shift for Harley M8 Bagger, '18 Softail
May 1, 2024
105
21
18
Used on my 2024 Street Glide for about three months until I sold the bike back in August. This is the genuine item from Kraus Motor Company, American-made and not one of the countless cheap-a$$ knockoffs.
Purchased new in May for $92 plus shipping, yours today for $49 OTD.
Kraus model UN-FC-80-B, black anodized finish.
From the Kraus website...
Small improvements can make a big difference.
The Kraus EZ-Shift changes your shifter’s leverage ratio so you can easily find Neutral, even at a dead stop.
Find neutral on M8 transmissions, at slow speeds. Greater leverage makes smooth shifts across all gears. Makes shifting 20% easier. Enhances your riding experience. Made in the USA of American billet aluminum. EZ-Shift finds the right gear every time.
Use with stock shift or aftermarket levers, works great for short levers. Easily bolt it on in 5 min. Fits all M8 Baggers and Softails. Billet Machined from high grade material.
This small but effective component makes a big difference in your riding experience. Offsetting the shift location changes the ratio to create just a little longer throw on your toe lever. This smooths out the gear change, resulting in an EZ shift.
It’s a must have if you ride in cities or traffic, your left hand and clutch will thank you. Holding that clutch lever in continues to drag the clutch creating heat in the primary and motor. Your bike will run cooler and your clutch and fluid will last longer if you pop it into neutral at the light and release the clutch.
Not to mention trying to back the bike up in gear, having to kill the motor to get neutral… Don’t worry your buddies will wait for you!
All necessary hardware for installation is included.
For Twin Cams, see the fitment specific product page.
Must have OEM transmission arm PN: 33900175. Non OEM, straight style shift arms will not work.
NOTE: I pulled a lot of parts and accessories off the bike before selling her so check my profile to see what else is available as I find the time to list everything.
Webike Japan
