tri bar light question
notring
9
Here in Europe we don't use tri bar light but standard rear light
I would like to add a tri bar in addition to the standard one.
But what does "speaker" "input" "ouput" "pc" "abs" ecc. means on a tail light????
The Fascia Lamp or Tri-Bar has two connecting points "INPUT" and "OUTPUT".
On USA domestic models INPUT is connected to the electrical feed harness from under the seat. OUTPUT is connected to a short harness that goes up to the tail light assembly.
All other markings are manufacturing and part identification Data and can be ignored.
Good Luck,
Blues
If you don't have access to a lift/stand, have a buddy move the bike off the kick stand for you and that can lean it a little bit helps. Have a bright light that you can position to see. A T25 torx, 2 screws and its off, or in your case on. The question I would have is do you have a wiring harness to connect to since you have tail light installed already?
Previous owner made some **** on wiring...
There is a connector (3) it should be used to attach the tri bar I think. But it is used! :mad:
The USA tri bar light is different from Europe and Australia. The Australian model has the empty fascia and the wiring does not plug and play so the HD or CD lights do not work without redesigning the wiring. It can be done. I am waiting for the bloke who did it is Australia to take some pics of how he changed the wiring. Some have just added a red LED light into the fascia and this is cheap and easy but again, waiting for the wiring instructions to be shared.
Ride511 I am also waiting for further information on this as I am in Australia. It would be great to get the tri bar light operational.
Tri bar light hd international models
Here is how i did install the tri bar light on my street glide 2014 hdi model.The light is empty here in europe.Take off the empty light from your bike,take off the smoked lens its glued.buy a tri bar light from biker choice part nr 482761 oem#68358-07 take off the smoked lens on the new tri bar light remove the led lights in side the new light and install it to the old light, first you drill a 10mm hole on the left side of the old light for the cables.Order cable from harley davidson part number 69200772 install this under your seat there is tree cables that runs to the tri bar light. Install all back on bike and you are done.If harley dont make a tri bar light make it your self!!!street glide need some extra brake and running light.See harley led light kit 68000111 for instruction where the wires conect.IMG_2145.JPGIMG_1156.JPGIMG_1158.JPGIMG_1159.JPGIMG_1155.JPG
