Vance & Hines headers with Rinehart pipes
Marsha
4
I need some help! I have a'14 Street Glide and have the Rinehart true duals with auto-tune and power commander with screaming eagle filter. The performance is great, however the design of the left header pipe is unbearable with the heat on my left thigh. I was thinking about changing my header pipes to V & H and using my existing Rinehart pipes. Is there anyone else out there doing the same? I like the design of the V & H header pipes 'cause the left header pipe goes under the frame. Any ideas?
Sent from my XT1080 using Tapatalk
Just get the powerduals... increase the performance over true duals as well
This^^^..........It's what I did and it has great low end torque and a very nice sound!
My buddy has the V&H power duals with Rinehart mufflers on his SG and it sounds really good. The dealership where I bought my SGS also recommended that I go with this same setup, but I decided to keep mine all V&H.
If you purchased the complete Rhinehart True Dual system (headers w/ slip-ons) it is extremely important to note that you will not be able to use the mufflers off of this system with an aftermarket header such as the V&H. This is because the mufflers used on a Rinehart True Dual system are designed for 2-1/2" diameter headers where as most aftermarket headers (including Vance & Hines) are 1-3/4" diameter.
Just something to consider as you think about your options.
Lindsey :0)
Lindsey :0)
Good call Lindsey... thanks for sharing that valuable piece of info!
I appreciate all of your responses. I am possibly looking at the Rinehart Slimline Duals. I haven't decided yet.
I have the Rinehart 4" Slip-Ons with the V&H Power Duals and Arlen Ness Big Sucker, all tuned in with the V&H FP-3. I've had them for about 500 miles- Terrific set-up. Sounds like this is what you want to do.
You got any videos? I'm in the same dilema...I want to go with the power duals but don't know which slip-on yet. I read a lot of good stuff about the set up with the rineharts but I haven't heard them yet.
I would, but bike is in the shop: 5,000 mile service and new clutch. It does sound really, really nice though.
24CVORider
