Will these work on my SGS 14 "plug & play"
Yes they should work. For how long and the amount of light output you get is the question.
The problem you could face is overheating
I will say I have 5 watt CREE LEDs as backup lights on my truck and they are damn bright.
The Custom Dynamics disks work very well. Most everyone here is using CD. Good luck with your search.
I'm one of the few NOT using the CD rings...
However, I went with something similar to the 24 element bulb (8th one down from the top) on mine and I actually like the way it came out.
Except I ordered my bulbs from superbrightleds.com.
One tip though, if the bulb you go with is shaped like the one I pointed out, you're going to have to modify your rear housings to make it fit. Fits perfectly fine on the fronts though, oddly enough.
I use CD... I always get told how bright the tails are.... the full disc encompasses the entire bezel and super bright. I run CD dynamic rings up front whic are white and blink amber...
Is there a plug & play that you guys recommend for the headlight??
Daymaker is what I have... The OEM headlight has a dual bulb setup which means you have a harness that comes off the main harness and splits for lo and hi beam. The Daymaker ( as an example ) has a single plug type connection... therefore you need to buy a harness from HD ( $20-$25) to use an aftermarket single plug type headlight. It's a very simple process.... it's not rocket science by any means.
There are several different aftermarket headlamps out there and much discussion in this forum about headlamps.... do a little research and choose the one YOU want...
I use CD... I always get told how bright the tails are.... the full disc encompasses the entire bezel and super bright. I run CD dynamic rings up front which are white and blink amber...
+1 here too
Harley day maker here to
And YES.... there is a difference between the HD installed Daymaker and the Daymaker you buy from the parts guys.... Take a close look....
FACTORY Daymakers have low and high beam lenses are IDENTICAL size... the others have a larger high-beam lens on the bottom like mine.
Mine was Dealer installed
Interesting Spazz. I did not know that! Does it make a difference in the beam throw??
Why would they sale two different lights but with the same name Daymaker? Is it the same price? I guess you could bitch and see if you could return it for the better of the two, you paid for it.
Myself I went with the Daymaker LED Reflector which is awesome and 100 bucks cheaper.
I've got the aftermarket HD daymaker for $525. Pricey but I sure like it.
Why would they make two different projector LED headlights? I'm gonna have to check this out. Gotta got to the dealer tomorrow anyhow.
I can't answer that Mojo... I have not been able to get the two (from people I know ) in one place to compare.....
I have NO IDEA... but they do..
THIS is the FACTORY Daymaker.... notice the lenses are EXACTLY the same size....
Here is the one that EVERYONE ELSE gets when you buy one from the Dealer...
NOTICE THE HI BEAM ON THE BOTTOM IS LARGER than the top low beam lens...
67700040A_OB_ALT
jdtech17
