Cam for my 2023 Street Glide Special
HARLEYGUY1974
6
Any recommendations for cam that will give me good power on my 117? I have to use Harley parts so that I do not void the warranty. Any help would be greatly appreciated.
Depends on the rpm range you do most of your riding at, how much time is spent 2 up, and terrain elevation changes.
I'm down in Warren, but lived in Oscoda for 5 yrs courtesy of the USAF.
Figured you were from Michigan. So am I. I do most of my driving here in Michigan. Mostly highway driving. Looking for a cam that will help with performance and sound good also.
  • Like
Reactions: buck99rog
2017 S.G CVO running Zippers 468 cam highly recommend. Great torque plenty of top end for touring
(in my application) Good luck!
To keep your warranty intact, the only option that I see for you is the 447 torque cam. With changing the cam you'll also need a new air filter and at least some slip-ons.
...a year later, Im new so forgive me. Im only posting because I am also a Michigander, though I escaped a while back... Im getting ready to venture into the world of "upgrading" my 2020 SG Special. Ive already got a nice breather (Zombie Breath by Tab Performance) on it as well as some pretty sweet slip-ons (50 Cal w/ Zombie Baffles also by Tab) but Im thinking the cam situation is next. All my research points to the Woods 22X, Zipper 468, S&S 485 or 475, or Feuling 465, or something by Redline(?) which turned out to be more for racing so thats out...
Is there something that you like about any of those over others? Any I should absolutely avoid? Im generally riding solo (until she gets a helmet and a bit of courage) with a crew of mixed bikes, most a lot louder than mine due to their tunings. My bike has no issue carting my 150lb self around anywhere, but it does seem to be asking for something more...I figure something to round out the power curve as I mostly keep it under 60 on this island so some low end would be nice. Crossing the island requires a climb from sea level to about 6500 ft, give or take, and back down again. thats where the middle powere would be appreciated. Right around the 3k RPM mark. Though ive never really had any issues, I often wonder if the quick elevation change messes with the engine. Ive got a DynoJet that stays on the bike but Im afraid to go messing with it...
Anyway, sorry about the ramblin (told ya Im from Michigan lol), but Im just curious what others think about that "stage 2" area for Street Glides. Its like, I dont NEED the power, but I AM going to upgrade so if Im going to do it anyway, I may as well get the most bang for my bike...I mean buck. Why not make a sleeper beast?
How many miles are on your bike? Which dynojet product do you have? The Wood's 22xe or xd and the Star 30/30 would be the choices for me.
Get adjustable pushrods, inner cam bearing, and new lifters while you're at it. Adjustables because then you won't need to take off the rocker covers, boxes, and rocker arms ( time consuming).
Check to see if you have the newer oil pump in it. It'll have a seal on the back side of it. That seal helps with savaging the oil out of the crankcase, preventing sumping.
Thanks for your reply! Ive got 22690 miles as of just now. Ive installed the DynoJet Power Commander 6 for 2017-2020 Harley-Davidson Touring because someone said thats what i should do until i start messing with the cams. It may have been a financial decision. It was almost two years ago. I dont know. Im seeing an Autotuner they make that supposedly adjusts on the fly? Im wondering if this would be useful with the elevation changes....or maybe what I have is good enough? I can read all the specs, but I dont understand the language, if that makes sense.
Can you tell me why you would choose the Woods or Star over the others? I like the time saving ideas of adjustable pushrods as my local mech charges $165/hr for Harley work. Would they need "re-adjusting" over time or is that not really an issue? Ill do all my own non-mechanical work but, if it involves the engine, I take it in. I have learned that I do have the new updated non-sumping oil pump.
The Wood's and Star cams that I mentioned are low end torque cams that, when tuned properly, provide a lot of torque near 21-2200 rpms.
I've had my adjustable pushrods in for 13k miles now and haven't needs to readjust them.
Which tune calibration did you load into the power commander? Because what I'm seeing on the dynojet site doesn't have anything listed for your setup. Closest that I see is for stock exhaust and high flow intake. That would be the issue with your feeling that the bike feels like it needs something more. Your exhaust isn't helping pull the exhaust gases out of the cylinders. Even though your pushing more fresh air at the combustion chamber, the freer flowing pipes arent pulling the gases out fast enough to allow all that fresh air in. Basically a backlog of air trying to get in. Which causes a dip in performance until the exhaust can catch up to the correct scavenging of the gases. When properly set up, the exhaust system actually helps pull some fresh air in.
The power commander can only adjust 2 things, fuel and timing. And that's only if you manually adjust them. The auto tuner from dynojet works with the power commander, but your base fuel maps need to be spot on for it to work correctly.
My advice, ditch the power commander and thoughts of the auto tune gear. Get it on a dyno and tuned properly with the device (flashing tool) that the tuner (the person doing the tuning) is comfortable working with. If you're not willing to buy a flashing device, (power vision, fuelpac, tts master tune, or direct link), I believe only the tts is the only one that you can't purchase a tune license for. The other 3 you can.
  • Like
Reactions: waialeasdad
i noticed that as well, regarding the tune calibration. mechanic said he had more of a selection of tunes that he could use than dyno offered so he did that. i dont know. i do know the bike definitely felt better and more responsive than when i bought it. ill look into your recommendations and ill update as i actually make changes....
now i might have to start a new forum to figure out why my speakers suddenly decided they werent going to sing to me anymore...maybe so ill listen to the bike more? lol oh boy....
Ufff. Just haphazardly throwing a tune in isn't the greatest of ideas. Even if it is a close match. Any motorcycle tuning shops on the big island? It really needs a proper tune.
If you have a multimeter you can check the speakers for continuity. You can also check the head unit out for voltage on the speaker wires.
Any cam will help, but my personal opinion (and I've talked to other people who know what they're talking about) is Screamin Eagle parts just don't have the power of some other brands. I have a Woods 22XD and it's excellent. You're pretty much limited with your warranty situation
chops92
